Doug
I checked the flow sensor recently and noticed that the sensor has a rather small orifice through which the fuel must pass. It appears to be no larger than 0.125" in diameter.
Has anyone taken the time to do a max fuel flow test with a Standard Facet fuel pump setup on their RV?
If so, what flow rate figures did you see.
Also, with such a small constriction I am considering mounting mine inside the engine compartment after the gascolator (ie after the fine filter gauze) to ensure no debris will block the unit.
Any other comments would be welcome.
Doug Gray
Doug Gray
