I'm finally diving into the FWF wiring for my EIS and boy is my head spinning. I think I've figured out where to place the EGT probes but am confused by the install manual on the type of wire required. The wires that come attached to the probes are obviously special, but are not long enough to reach my panel. Meanwhile, the wires that come off of the EIS are plenty long enough to reach the motor. Finally, the manual says that to extend the probe leads requires special yada yada.... So, what is SOP here? Do I penetrate the firewall with the wires from the EIS and then connect near the engine to the probe leads? I'm trying hard here not to sound stupid, but I'm not sure it's working. Any expereince would be appreciated and pictures are the best.
