I've got an EIS 4000 in my RV-8, and I was quite concerned about the apparently busy, two line LCD display. I decided to also put analog round dial tachometer and MP gauges in my panel, as I considered that they would provide a much better, "at a glance" display of rpm and MP. Well, after flying my aircraft for 17 hours, I find that I never look at the round dial tach and MP gauges. My eye falls right on the rpm and MP fields in the EIS 4000 display.
There are a lot of data items in a small space, but if you press the "Display" button the data items are replaced with labels to help you remember which data item is which. Also, if a parametre goes out of range, the display changes to one that shows that parametre with its label below it, to make it 100% clear which one has caused the warning light to fire.
I agree with the other's comments on the usefulness of the warning light if a parametre goes outside the limits.
The leaning feature is very well done. The fuel flow option works very well.
There are other nicer looking engine monitors, but there are none that come anywhere close to the "bang for your buck" value of the EIS 4000.
