GRT's install info shows a tach input wire connecting to the P-lead contact on the mag with a 27k ohm resistor in series. Seems like any tach signal needs to be a pulsed signal proportional to engine RPM. Why would a connection to the P-lead contact work? I thought the P-lead received a steady 14V through the ignition switch. What am I missing here?
