NYTOM
In order to see Fuel pressure would the EIS 4000 head have to be sent back to GRT or can it be programmed in right in the panel. Found my original wiring diagram that came with it but there?s no mention of fuel pressure with all the other ( oil pressure, CHT, EGT etc. ) probe connections.
all sensors, except oil pressure, can be tweaked to work but will require some knowledge and math.
Larry
Tom,
Check out the thread linked below. This is in the Classified section and will be deleted next month. Therefore, be sure to save any info you find useful, as this info will soon disappear from the VAF site. See
http://www.vansairforce.com/community/showthread.php?t=174946&highlight=EIS
Fuel pressure can be added using one of the 6 available auxiliary inputs. Low pressure [carb] will need a different sensor compared to high pressure [Fuel Injection]
Charlie
Tom,
Charlie
Outstanding Charlie. Just the info I needed. Thank you. :)
