NYTOM
Having a problem with the VDO 0-30 psi senders reading very low pressures in the 0 to 3 psi range. Have tried two so far. Just wondering if anyone has found a replacement with maybe a 0 to 15 lbs range that might be a little more accurate or at least read very low pressures better. Thanks for any help.
