skidookid
Active Member
eFI II igniton system
Looking at replacing a Bendix dual mag with efi 2 system. Looking for info on people using efI II system and how did you hook up dual batteries. thanks
Just search EFII on here. Most use the buss manager
If you email me directly I can send you my electrical schematic. 2 batteries 2 alternators.
What is "efi II"? Do you mean two EFIs, or [Lightspeed] Plasma IIs? Whether it is two EFIs or Plasma IIs, Lightspeedengineering.com has installation manuals that show how to wire up two batteries.
Is this an H2AD engine? That requires more tinkering to mount the triggers.
-Kent
Battery post to fusible link, to ignition switch, to ignition unit. Simple, reliable, independent of all other electrical. KIS is good.
KIS is good.
Unless this is the kisser
