My question is how to measure for the hole location. I understand that I want them all the same distance down the pipe. I'm using a 4 inch piece of string because dynon suggests 2-8 inches and my #4 cylinder doesn't have straight pipe until that distance. I'm measuring the side of the pipe, almost as if I was measuring down the center of the pipe if that makes sense. You can't measure the outside or inside of the bends because that will give different placements. Is this the way to measure these holes? Also, in all the other posts it mentions to leave the sparkplugs open and general maintenance. Well what are general maintenance things and any other thing to check before I drill these holes. Thanks for the advice,
Nick
Nick
