Flying Patagonia
I'm New Here
Hello everybody!
We are fine tunning a dual EFII ignition and injection system, (SDS / FlyEFII) into an Aerosport Power -375 engine, could anybody please share the setting values that best work for this configuration?
Or may be into a IO-360....
I have IO-360 table data but it seams that my engine requires at least 20% more fuel to run smoothly and into temperature ranges.
And other thing is happening that difficult the tunning procedure is that the AFR (PLX Wide Band) has fluctuations in the readings.
Thanks!
