For those that have to connect the left and right fuel injector banks, what routing did you use for that fuel hose?
My first plan was (from the left side) to pass behind the starter, then below the lower front engine case, up under the right baffle ramp to the right side.
I had a long fuel hose made by Tom but did not consider the snorkel...
The hose is too short because it has to go around the snorkel so I need to have another made or fabricate one myself. Not sure there will be enough space though. I want to avoid going in front of the ring gear, I saw that option once, I find it scary...
I'm also considering going 180 back, below the injectors, then behind the engine to join the other side. That would require a longer hose but simpler to secure.
Happy to get suggestions, ideas and photos...
