kearney
Hi
Yesterday I decided to collect a little real world data flying behind the SDSEFI.COM Electronic fuel injection / electronic ignition.
To start I have been tuning my ECU maps so that I don't need to touch the mixture knob. I have set the maps so that at altitude the engine is running close to best power / stoichiometric. When I flip the magic LOP switch, I set it so that the spark is advanced by 6 degrees and the engine is leaned by 8% or so. I was shooting to be running LOP by 40 - 50 degrees.
The table below shows the results. The data was collected when it was a bit bumpy at lower altitudes but directionally it seems consistent with what I was shooting for. The spark advance seems to have offset the power loss I would have otherwise seen as I reduce fuel flow.
I do like being able to tweak the engine in flight!
My apologies for the poorly formatted table - I couldn't sort out how to make it presentable when posting.
Norm LOP
Avg Avg
Alt MP RPM OAT FF TAS CHT MPG FF TAS CHT MPG %
10000 21.1 2390 27 12.5 167 348 13.36 11.6 162 341 13.97 0.05
12000 19.8 2390 17 12.4 165 347 13.31 11.4 168 346 14.74 0.11
14000 18.3 2390 8 11.8 161 352 13.64 10.7 164 338 15.33 0.12
16000 16.8 2390 -2 11.2 156 339 13.93 10.5 163 328 15.52 0.11
18000 15.5 2390 -12 10.5 159 327 15.14 9.9 160 325 16.16 0.07
Hey Les.
Time to update your profile! Unless you want everyone believe you commute 200 miles to your hangar (down the taxiway from me) daily!!
