rockbottom
Active Member
I'm in the process of mounting the horz. stab. to my RV8 fuselage and have begun drilling the 4 bolt holes through the HS-814 splice angle, aft deck, and 810C angle that spans the 810 bulkhead. The two outermost holes also penetrate the 887 upper longerons. Per the directions I've drilled the first holes with a #30 bit to be followed up with a #12 to accept the AN-3 bolts. You can see from the accompanying photo that the outermost hole doesn't have enough edge distance on the 810C angle underneath.
As I see it, I have two options: Add a 1/8" thick doubler underneath the flange of the 810 angle that extends past the end of the angle and use longer bolts, or (the least desired option) rip out the 810C angle and replace it with a longer one. The only problem there is that it wouldn't be much longer than the one already installed and might not provide the desired amount of edge distance.
Any suggestions?
James Baker
![2wnths5.jpg](/community/proxy.php?image=http%3A%2F%2Fi47.tinypic.com%2F2wnths5.jpg&hash=2b3271455f298c521c9c7fefcd5aeca2)
Any suggestions?
James Baker
