I'm almost sure I screwed up on the first parts of my emp work. It says in the manual to smooth all surfaces and remove scratches,radius end R-1/4. These are parts HS-609PP and HS-710/714. I did all but HS-714. After reading a post on edge dis. I checked the ends and most don't have 2X the rivet diameter from edge to center of the rivet hole, some 1/32 short some 2/32. 2X the rivet dis. is 1/4" and all I did was remove the dad-dang machining marks! I measured HS-714 which I haven't work yet and it is exactly 2X the rivet dis. It appears I can't so much as breath on the ends without taking to much material off,all you can do is do the R1/4" on the end sides and totally leave the end material as is or you have lost your min.edge distance on the ends of these parts. Since these are spar reinforcment bars even I know there critical parts not to be fudged. First am I seeing this correctly and if so why the heck is it so close from the factory and why wouldn't there be a warning not to mess with the ends when this is the first thing you do and being a beginner? it says smooth the marks and you can't at this spot on the part. I'm upset but at least I found out there was a problem and can regroup. Bottom line are these parts junk,I think so. Tell me I'm wrong. Gene
