aarvig
So I am working on my left elevator (RV-9A) building the gusset (cuss-it...as Smitty calls it
) that goes between the trim spar and the root rib. I made one part and snarfed it up. Made a second one and made it to small. Made a third and JACKPOT! Looks good. So I drill the initial hole (#30 final size) at 1/4 in and 1/4 up. Comes out perfect. I cleco it into the trim spar and match drill through the root rib into the cuss-it. All holes drill nicely. But drat the edge distance for the 470's is perfect on the trim spar side but on the root rib side I am about 1/32nd shy of the mark. Should I remake the flappin part or leave it and build on? Thanks in advance.
