For Those who have installed the Uavionics Echo UAT. When you have all the proper settings programmed, should squawk code and density altitude be showing up on the monitor page of the install app while you?re on the ground? I?m using a GTX327, with the UAT sniffing it?s signal. Rs232 input with FADC w/ altitude selected for input from my GRT Sport SX, Icarus selected for output. GTX is not hardwired to the ECHO. I?ve confirmed that all settings in the GRT are correct.
Just want to make sure I?m not missing something before I take the airplane for a transponder check.
