fodrv7
It is a few years since I posted my "Leg Fairing Align procedure" and there must be quite a few new builders who have not stumbled on the post, so I thought it would help if I reposted it.
Here's a brief summary. For the complete procedure and pics email [email protected]
Pete.
Using the string to establish the fairing parallel with the ?steamlines?.
The string thing is standard Vans procedure. My variation is the use of 1/4" poly tubing to give more accurate and easily determined results.*Without the poly tubing bring the two strings together, it is very difficult to measure the distances between each string and the trailing edge, as you cannot get you head in at right angles to read a ruler, as the fuse is where you need to put your head to avoid any parallax error. But if you just slide the poly tube along the sting until one string is touching the fairing you can eyeball the gap to the other- say 1/16"- and rotate the fairing to make the equal gaps.
[/URL]
Uploaded with ImageShack.us[/IMG]
Pete.
![1legstringalign.jpg](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimageshack.us%2Fphoto%2Fmy-images%2F402%2F1legstringalign.jpg%2F%5D%5BIMG%5Dhttp%3A%2F%2Fimg402.imageshack.us%2Fimg402%2F3528%2F1legstringalign.jpg&hash=3e43e4ff04837a467a164a0b7c2f44dd)
