My -6 has had the standard Vans battery box with a Concord RG25 battery. My Concord died and I am retrofitting the ETX-900-VNT to the same location. If anyone else has done this, did you use the original battery box, and if so how did you secure the battery inside? If not what did you do? Also if you used the vented battery how did you route the vents?
