I see it mentioned in a few other threads but thought I'd ask explicitly: Has anyone installed an EarthX battery with the Vans supplied Silent Hektik voltage regulator? I've done W&B calculations and should be ok there, and also understand I'd want to run a wire to the panel for a status LED. I'm curious, how well does the battery fit in the existing battery box? How has your experience been with it? Anything else I should be aware of?
