Response from FlameMaster
Ben,
I did some searching and I found the following. The first link is an application guide for applying Pro-Seal. Proper application goes a long way towards eliminating "grip" problems down the road.
snipped
My "net" searching turned up no solid info regarding issues of ethanol in contact with Pro-Seal 890 or Flamemaster CS 3204. I have sent an email to Flamemaster, inquiring about this issue. I will report back, once I get an answer.
Charlie Kuss
After almost 3 weeks, I finally got an email response from FlameMaster regarding the effects of auto fuel and auto fuel with ethanol on CS 3204 (the fuel tank sealant sold by Vans) See below:
Linda,
I am building an experimental Vans Aircraft RV-8A. I have searched the
Internet and your web site. I would like to know if the ethanol in E10
gasoline would cause problems for an aluminum fuel tank sealed with
Flamemaster CS 3204 There are a lot of opinions on the various builders
lists, but no solid data. I thought I would ask at "the source". Thank you
in advance.
Charlie Kuss
I have forwarded your inquiry to our Technical Department. Due to your
concern I want to be sure you get expert information. Unfortunately, he is
out of the office.
Regards,
Linda Smith
Mgr. Customer Relations
Sales Department
Flamemaster Corporation
Dear Mr. Kuss
Flamemaster makes no recommendation on sealant compatibility issues regarding the use of alternate fuels either as a substitute for Aviation Gasoline (AVGAS) or as a blend with AVGAS.
Motor Gasoline, such as E-10 vary by producer as to additional additives which can effect corrosion properties also ethanol combines freely with water and if sufficient water is present can be subjected to phase separation taking the octane with it. Conceivably as many variations of E-10 exist as there are producers.
Flamemaster does not warranty the performance of fuel tank sealants or coatings subjected to fluids or fuels other than those specified by the applicable specification." "It is the responsibility of the user to determine the suitability for use utilizing the information contained in the applicable specification."
All Flamemaster sealants including CS-3204 (specification AMSS8802) are tested using JRF (Jet Reference Fluid) as a reference medium. The custodian of the specification chooses the particular JRF type and this may differ between custodians. The JRF used for AMSS8802 references Aviation Gas and Turbine Fuel.
Actual fuels including Aviation Gas, Motor Gas with or without Alcohol, and various Jet Fuels JP4, Jet-A are not used for either qualification or acceptance testing of specific sealant compositions.
The following information is presented without conclusion as to suitability for use
Tests conducted independently by a major operator during 2003
A material compatibility study to determine if a 50/50 mix of AVGAS and 89-octane auto fuel adversely affected (CS-3204 B-2) that is normally exposed to the AVGAS. Testing occurred between February 2003 and March 2003.
Mechanical testing included tensile strength and elongation, volume swell, and peel strength determination. All testing was conducted in accordance with the established ASTM and SAE test procedures outlined below. Thermal aging of all materials was conducted for 7 days at 120?F in one of three fluids: AVGAS, 89-octane auto fuel, or a 50/50 mix of AVGAS and auto fuel (which effectively has an octane rating of 91)
Peel Strength SAE AS5127/1
Tensile Strength & Elongation ASTM D 412 , SAE AS5127/1
Volume Swell ASTM D 471, SAE AS5127/1
The tensile strength of the CS-3204 B-2 material, aged for seven days at 120?F in a 50/50 mixture of AVGAS and auto fuel, was reduced by 38% as compared to the results of the thermal aging in just the AVGAS.
The volume swell results were ?2.2% in the AVGAS and +15.0% in the 50/50 mixture.
The peel strength results for this polysulfide fuel tank sealant were 40 lbs / 100% cohesive failure for those specimens exposed to AVGAS and 31 lbs / 100% cohesive failure for those specimens exposed to the 50/50 mixture during thermal aging.
All results observed were within the parameters of the specification AMSS8802
This test data has been received from sources outside of the company, it is provided without any warranty expressed or implied regarding its correctness.
Feel free to call or Email if you wish to further discuss this issue.
Respectfully,
Ken
-- Kenneth F. Chenard
Flamemaster Corp
Nadcap AS9100 ISO9000
