Mine works great
Total is about 350hrs on the airplane with E/P mag and O320. No negative issues whatsoever operationally.
Also, I'm able to aggressively run LOP and the engine runs smooth and cool.
I wouldn't think of going to regular mags.
Not tremendously scientific, but here is some anecdotal data:
Yesterday KRHV-to-KHHR we averaged about 7.6 GPH takeoff to touchdown. Hours were GPS flight time.
Cruising altitude 11,500.
KTAS~152
2700 RPM
18.5" MP
1C OAT
Not at all record breaking, but I'm happy with it. Typically its a bit better, but that route requires some low altitude cruise in the LAX special flight rules area that buggers the fuel burn average.
At mid teen altitudes my fuel burn typically averages under 6GPH takeoff to touchdown with 150 KTAS cruise speeds.
My prop is optimized for 19,500 density altitude, so I get low 150s cruise speed at 2700 RPM from sea level up to that 19,500 DA.
If I were building the airplane or if I keep it long enough for an engine rebuild I would prefer to have an injected engine. I would expect better fuel economy due to better balance between cylinders.
Sometimes I wish for a lightweight CS prop, but so far not enough to actually get one.
