Not a new product.
Not really a new product, I have been running it for awhile now and love it. Surprised more people don't know about it. So far its been flawless and works amazing. I have dual P-mags in my -4 and wanted the ability to monitor them and make timing adjustments. I first started with the factory I-CAD from P-mag running on a laptop and while it worked it was unusable in flight and could only look at one mag at a time. I then looked at the EI Commander but its crazy expensive and would require panel space. I have found P-MAG adjustments are needed but not on every flight so no need to have a controller in the panel, plus I really like my super clean panel. So then I found the Engine Bridge and its fit the bill perfectly. The install is super easy, just a few wires then a simple download from the app store and then poof I had full control and monitoring of my P-MAGS in flight. I run Foreflight on a iPad so now I can just swipe apps and see at all times what my P-Mags are doing. I recently had a coil pack fail on a P-Mag and I could instantly see it on the app in flight, when I got the P-Mag's back from Brad I even used the app to swing my prop through after timing them to verify they both showed the came crank position through the 360 rotation. Now I'm not going to recommend this but you can fully make timing changes flying along, I have done a lot of experimenting with different P-Mag advances and its really neat to instantly see Speed/CHT/EGT change with a new timing. Now P-MAG says don't make changes in flight for safety reasons and again I'm not recommending it but the Engine Bridge does a great job of it and sure does let you find the correct timing for your engine. I don't normally take the time to write a review of a product but the Engine Bridge EI is truly a great product at great price.
