JurgenRoeland
Hi,
I have been cursing, shouting, drilling out multiple and close to crying
Due to the construction order (because of the local inspection requirements), I have rivetted only one side of the elevators. Now that inspection is done, I tried to close the skins but realised that the farest extreme end rivet near the bend on elevator skin on E-703 is almost impossible to set if you cannot stretch the rib a little bit (which is impossible if you already rivetted the other side.
Anybody has a suggestion on how I can set in that tiny opening. I used various bucking alternatives such as the narrow bucking bar from avery, a screwdriver head, backrivetting. Nothing seems to work.
Is it allowed to put a pop rivet in there ? and if yes, which one.
