strangebru
Active Member
Am I correct in that the narrow edge of the trailing edge bar (E-01423) points forward and the thicker edge points rearward?
That is correct only for the elevator. All other control surfaces, like rudder, would be the opposite .Am I correct in that the narrow edge of the trailing edge bar (E-01423) points forward and the thicker edge points rearward?
