I have debated weather to throw a live grenade in or not but here goes....
I'm getting to the point in the wing construction where I need to make a decision on avionics components. I have had the opportunity to fly behind the GRT glass and have seen the Dynon at last years Sun-n-fun and both are impressive. The Dynon has a dedicated pitot for airspeed and AOA, whereas the GRT allows pretty much any pitot setup as far as I can see. The features on the integrated SkyView Autopilot are more impressive than the Honeywell I fly behind at work, however I don't know the track record of their system. The GRT that I got some stick time in had the TruTrack AP and it worked flawlessly. I know that the TruTrack is bullet proof. I realize that this is a bit of a Ford vs Chevy discussion. Both are priced comparatively.
I believe it will probably be several years before I'm finished with my 7 and at the pace these companies are moving a lot can change in that time. It looks like AP servo brackets can be changed after the wing is closed up, but your stuck with your choice of Pitot tube. Is there anything else to consider at this point in the wing construction.....
Thank's...."standing by for incoming"
