I am looking at wiring up the pitch servo and wondering if there is any reason why the power, ground and disconnect wires cannot be wired into the same d-sub connector as the four position wires. Only four of the 9 pins are used. I realize that the those wires would have to be split out before connecting with the hub, but why not use those extra pins? I plan to put a terminal strip near the hub, so the wire lengths will not be an issue.
