Changing MX time/date in SkyView Touch.
After setup is complete, the Maintenance Log is accessed from the TOOLS > MAINTENANCE (SkyView Classic). For instructions on how to use the Maintenance Log feature, see the SkyView Classic Pilot's User Guide, Rev. X and later, or the SkyView HDX Pilot's User Guide.
Each item in the maintenance log requires entry of the time basis (or NONE) to determine whether the item is not yet due, due, or overdue. • SETUP MENU > AIRCRAFT INFORMATION > MAINTENANCE LOG
o > LOG ITEM x
▪ > NAME (user-defined text, up to 14 characters)
▪ > TIME BASIS (NONE | DATE | TACH | HOBBS)
▪ > END TIME, HRS (if TACH or HOBBS was selected) or… > END DAY, END MONTH, END YEAR (if DATE was selected)
Your welcome.
It is in the SkyView System Installation Guide – Revision AM page 4-30.
Good luck.
Brian
