Working on that myself right now...
One or two inches, based on what others have done. Nuckolls recommends fibreglass sleeve to protect adjacent wires in case it pops.
26 AWG seems very thin though and also not available from Spruce. I'm thinking of using 24 AWG for the fusible portion and then 20 AWG for the routing up to the panel. The Dynon harness itself is 22 AWG (I believe) so if the splice between 20 AWG and 22 AWG is close to the EMS module it should help to mitigate risk.
I put these Littlefuse 1 amp fuses on my shunt leads.
I read that in the Dynon manual also, how are you going to terminate the relatively fine 26 AWG wire? The specs state that the OD for ETFE sheath is .032 or .040 depending on number of strands, that seems a tad thin for my fumbling fingers to work with. Even 22 AWG is a challenge. I wonder how the 26 AWG can be stripped cleanly and crimped securely in a ring terminal to match the screws on the shunt?
Those are cool. How do you connect?
