wirejock
The mounting plates is clamped in place and holes through the F729A Bell crank rib are match drilled into the plate.
Did anyone add additional fasteners between the bell rank rib and plate or the bottom plate flange to bottom skin?
Photo would be appreciated.
I opted not to attach to the bottom skin.
I sometimes do and sometimes don't attach to the bottom skin, mainly depending on whether the plane is painted and whether the owner wants unpainted rivets on an unpainted plane.
The Dynon bracket that I got from them did have a flange for the bottom skin, I dimpled and riveted it in.
