I've reached the point where I have put this off and I need to move forward. I am installing a dual dynon system in an RV 8 and need some input on where guys have put the magnetometers - I know the rules about ferous metal etc but what has worked? In the tail, on the wingtips - what has been the best place you have expereienced?
Secondly, if I put it on the aft end of the wingtip (whelen strobes up front) can the wire be run in the same conduit as the shielded whelen wire or has this caused anyone trouble?
Finally, have you made your own 4 wire bundle or is this something you have had made when wire bundles for the EFIS system are constructed? I will have my panel wiring done - I have no intention of trying this myself although a little 4 wire bundle seems doable.
Thanks for your input...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
