You need 5 Volts power, Ground and the sensor line. Obviously the sensor line needs to go back to the EMS, but that wire is already attached to the VDO sensor. Ground is best to come from the EMS, but your forest of tabs would work. For power the Kavilco needs 5 Volts (not the 12 volts from your battery. Five volts is available from the EMS.
