Berchmans
I am having an issue with display of the trim settings for Elevator and Aileron on my Dynon FlightDEC 180. I have sent a query off to Dynon but was wondering is others here might have encountered this problem. On the General Purpose outputs (GP) I have configured the Outside Air Temp on GP1 and it displays just fine in the upper left quadrant of the screen. I have configured the Elevator on the GP2 output and Aileron on the GP3 output. All use the 5 volt power supply from Pin 18 per the manual. GP2 and GP3 show accepting calibration with minimum readings of 0 and maximum readings of 500. The servo motors are Ray Allen. Take off setting is at 250. The manuals say the trim displays should be in the lower right quadrant but I get nothing. I have scrolled through all screens a calibrated several times. Thoughts on why the trim indicators are not appear on the display?
