mv031161
If it requires the 25 pin connector, does anyone has one we can rent or borrow?
Any way you can get to pin 10 on the 25 pin connector connected to the D-100 in the plane?
Connect that to pin 2 on a female DB9 connector and any ground in plane to pin 5 on the DB9 connector and you should be good to go. DB25 pin 22 to DB9 pin 3 may be needed too if you use the Dynon support program.
Connect the DB9 connector to a DB9 serial to USB adapter (or directly to a DB9 connector on an old laptop or computer).
If you want to connect to it out of the plane you'll have to supply +12V to pin 1 and ground on pin 3 and 9 on the DB25 connector. (DB25 pin 9 to DB9 pin 5)
Actually if you have internal battery in the D-100 all you'd need is:
DB25-9 to DB9-5
DB25-10 to DB9-2
DB25-22 to DB9-3
Note that this is not a standard DB25 to DB9 serial cable.
https://www.dynonavionics.com/includes/guides/EFIS-D100_Installation_Guide_Rev_H.pdf page 3-4 EFIS SERIAL HARNESS
https://www.dynonavionics.com/includes/guides/EFIS-D100_Pilot's_User_Guide_Rev_I.pdf page 9-3 Appendix B: PC Support Program
Finn
