roadrunner20
I've been doing some taxi tests prior to my first flight but do not get an ASI reading.
Is it true that the efis will not display air speeds < 30Kts?
I've done my pitot static check and all is well with no leaks.
On my D-10, the airspeed comes alive on takeoff in the low-mid 30 kt range, so what you are seeing is normal.
Thanks guys.
You're the best.
I didn't want to fly the first time using my gps backup for an asi.
Dan,
Now that we're got that sorted out, can I please, please convince you not to do any more high speed taxi tests. They are a waste of time and dangerous and have little to no value.
sprucemoose said:
Dan,
Thanks Jeff,
Don't worry, I'm not doing any highspeed taxi tests.
My gps indicated 7 or 8 mph.
I just thought the asi would have displayed something. I'm ok now and ready for 1st flight Saturday, weather permitting.
Just so you can hear it from us:
On Dynon EFIS products, the ASI "comes alive" at 30 KTS as the speed is going up and it "dies" at 25 KTS on the way down.
Thanks everyone.
I did my first flight Sat 7/8; see my first flight post. I remember noticing it around 45kts and I was flying within seconds. I can't tell when it actually came alive as it happened so quickly.
All I can say is "it worked great"!
What a blast!
