Kokemiller
I have a D180 and Dynons dual axis servos in my 9A and for the last year and a half have had an issue with it altitude setting. When I set the altitude, it always descends 60-70' from my set point. It is not slipping. For example, if I want to set it at 7500' I either have to set it at 7560' or us the alt bug to dial up to 7560'.
I have talked to Dynon at the last two OSH shows and they said they are aware of the issue and are working on a solution. I'm beginning to wonder if their solution is the skyview.
Curious to know if anyone else has experienced this and if they have found any way to remedy.
