Terry Wendling
I'm New Here
Is there a PORT for manifold pressure on this engine? It's an up draft, carb-ed engine with a f/p prop. I realize that one does not usually have this info on this engine, except the Dynon D-180 likes this info so it can do some stuff like % of power indications. I have not found a port for this and wondering what you do if there is not a port for MP.
It's there...
Terry,
It's on the cylinder head... remove one of the primer lines if you have four... if you only have three, it's on the other cylinder in the same location....
gil A
