I have a Dynon D-180. Recently it has started showing LOP almost all the time. Even with the mixture set full rich it sometimes shows PK or LOP. The engine seems to be running fine, it appears to lean normally (i.e. i lean it out, watch fuel flow gradually decrease, and eventually the engine starts to run rough when leaned too much). Idle-cutoff works. EGT readings on the Dynon all look reasonble (mostly in the 1300's, depending on power setting).
Any thoughts as to what could be causing the chronic LOP reading?
