billpilot1
Active Member
Boy, I hope someone out there can help me. It's Sat and I probably can't call the support at Dynon till Monday. I have installed the Dynon Auto Pilot in my RV7 and during the AP Configuration everything was going fine. Have the New Software installed (5.0) and everyone was talking to each other. Then Doing the Servo test. I moved the stick Forward and right, Forward and left, Back and left, and Back and right (what ever order it asked for) and after centering the stick and pressing the OK button, it's supose to pull back and to the right under the power of the servo.....It only goes back (climes). So it asked if it did it right and I have to answer NO. That is as far as it will go. Under the possible reasons it says that "the most common cause are not enough travel being detected, or too much travel." Mechanical adjustments muct be made.
OK during the installation it says that the hook up should be on the outer most hole of the servo arm and it sounds like that should stay there and you should not have to move it in to the closer holes. I think I have it just as the photo shows it. I have the dimensions set as presented. The only thing I think I can do is shorten or lengthen the connecting arm.
If that is it, any ideas which way to go, or what to look for that might tell me.
I sure would like to get back to it Tommorow (sunday).
I'm open to any help you might have.
Thanks in advance.
Bill
Thanks in advance.
Bill
