ty1295
Drawing 27A, Section C-4, Vertical stabilizer the plans call for a AN3-6 bolt on the left side with a washer superglued to AFT side of stop.
Does anybody have a picture of where this washer goes exactly. I am 99% sure I got it correct. I have a washer between the elevator stop and the vertical member of the tail on the left side only.
Just be nice to see a picture or verify 100% this is correct before I finish buttoning up the tail mounting.
The nose of the vertical stabilizer is offset to the left (looking from aft) to counteract the slipstream from the propeller. Once the front spar of the vertical stabilizer is clamped or clecoed into the F-981 vertical stab attach plate, it should be obvious where the superglued AN960-10 washer goes. There will be a space between the aft spar of the vertical stabilizer and the F-921D up elevator stop and the vertical stabilizer aft spar.
