brian
The heater on my -6A is a muff over one exhaust pipe, then the air goes up to a flapper valve on the upper part of the firewall. The heater control valve opens to allow thie heated air to go into the cabin. However, I noticed that the side of this flapper control box has an opening on the side of it. When the heater is "on", the flap covers that hole and opens the hole into the cabin. When the heater is "off", the flap covers the hole into the cabin and opens the heater output to the side hole. It appears to me that, in summer when I don't need more heat under my cowl, this is dumping heated air into the upper cowl area.
How are you others dealing with this? I thought I should either rivet a plate over the side hole, to block airflow entirely when the heater is "off", or rivet a flange over the hole and run some 2" SCAT tubing down to the lower cowl air exit.
What do you all think about this?
thanks,
brian
thanks,
brian
