mlwynn
Hi Folks,
I am about finished gathering parts for my FP->CS conversion. I have an IO360M1B engine with a rear mounted governor. The question is, do I need to drain the oil before I take off the pad cover and install the governor? I would hate to find out that it is located below the oil level and have a lap full of 50 wt.
Gov drive install
No need to drain oil, it is way below level of the governor drive.
Don Broussard
RV 9 Rebuild in Progress
Which FP prop are you removing? If you're thinking of selling I could be interested... Any details would be much appreciated.
Thread most likely to get hijacked
I could see this thread getting off into the weeds rather quickly......:D
