mbuto
Member
Hello,
I'm trying to upgrade the leading edge landing lights on my -9A and I'm having difficulty getting info on this product from DW. Can anyone message me for further assistance?
Mike
It's possible to make your own mount quite easily, that's what I did for some Flyled spot lights. Just make the hole whatever size you need for the lamps.
Hello,
Mike
DW sells a lamp less leading edge installation kit for $80 (each). Or, you could just modify what you have now for a PAR 36 bulb. I did this on my used RV6 kit that I bought. The original LE light brackets were set up for a rectangular light. I cut the bracket to allow an opening large enough to accommodate the PAR 36 round light. I made a patch out of .032 that fits the PAR 36 bulb, and riveted it to the original wing bracket. Then I made a bracket clamp to hold it in place - just like the one that they sell. It was an afternoon of fabricating, and it worked out just fine.
Yes, and it's that kit that I need info on. From the DW picture I have no idea if it fits in my existing landing light cut out or how it is secured to the wing interior. I do not know if all 9A landing lights start at the same baseline. If I can see the plans/instructions then I can see if it works or need to go another route. I am not a builder so do not have ready access to tooling. Willing to learn of course, but I need a clear path first.
Based on what I've read on VAF, Duckworks is a small company and it can take a couple of weeks for them to respond.
Another way to get the info would be to post in the VAF RV-9 forum a "wanted documentation for Duckworks landing light cutout" , i.e. make your request more specific. And maybe also include a photo of your current lighting cutout.
Vans sell the Duckworks kit so tech support may also be able to assist.
https://store.vansaircraft.com/duckworks-landing-taxi-light-kit-for-rv-9-9a-ll-dw-02-rv-9-only.html
