Xkuzme1
Looking to see if anyone has a wiring diagram for a Dual PTT system using diodes and resistors. I don’t have room, nor do I want an audio panel. I also do not want a switchable unit.
I want to connect my com 1 (KLX135a) And my Com 2 (FL-760) and My SPA-20” intercom all together with 2 PTT switches. I want to hear both radios and talk on which ever PTT switch that I press.
Does anyone have a wiring diagram using diodes and resistors to help make this happen?
I’ve done a fair amount of searching. Most threads revolve around adding a switch or adding an audio panel.
Thanks!
Tinker.
Each radio's output to a 500 ohm resistor. Tie other ends together, and tie that to the headphines.
Each ptt to one radio's key input.
My choice would be a single pole double throw switch for transmit selection. Each radio's key to opposite sides of switch, center terminal to a sinnle ptt switch.
Charlie
