I'm using the Aeroelectric Z-14 architecture with dual PC-680 batteries mounted on the firewall of my RV-9A. The second battery will be mounted on the pilot side at the same waterline as the primary battery. My engine is an IO-320 with a constant speed prop. Alternators are 60A B&C primary and 20/30A B&C backup (vacuum pump pad mounted).
I recall pictures of dual firewall mounted batteries, but after an extensive search on this site was unable to find any or they have been deleted.
I'd appreciate any pictures of the second battery, battery box, battery contactor and cross tie contactor, and battery wiring to the contactors. Any advice also appreciated.
