Stockmanreef
Is it OK to enlarge the holes in ring terminals? The cable supplied with the kit for the alternator is not the correct size ring terminal. The internal hole had to be enlarged to 1/4" from 7/32" (I think). The ring terminal is 15/32 wide, so the ring portion is still thick. I do see exposed Copper now that it the hole has been enlarged.
This is the second terminal I had to replace or drill. I wonder why Van's even bothers putting the terminals on in the first place.
