No problem deferring this. I used a cheap Harbor Freight punch set which has a 1 1/8" hole punch. It is perfect for the control lines and electrical pass throughs.
Start the hole with your step drill out to 3/4", then use the punch to finish the job. As long as you can get the punch in the starter hole and put a wrench on the end of the punch, you can create firewall holes in fairly tight quarters.
