Yesterday I was having one of those brain-blanking moments that you're not supposed to have at my age. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I was drilling the #8 screw holes for the fuel tank access hatch into the ribs. I did it first with a #30 bit, as I know that's the right size for the pilot hole. What's the right size for the final hole? #19?
As a side note, for final-drilling the tank-to-spar skin screw holes, where the manual says use #19, I got slightly impatient and just bought a 5/32" bit from Lowes Aircraft. According to my conversion charts, it's around a #22 bit. I also got a 11/64" bit, but that's between a #18 & #17. I'd rather be the hole be smaller than larger. Is/was this okay to use the 5/32" bit, and if the final hole size for a #8 is a #19 bit, I'm guessing using this bit would be fine?
Thanks. The brain just wasn't working yesterday.
