S spriteah Active Member May 22, 2011 #1 Hi all, I have come to a spot on page 08-03 where it refers to a drill guide to assist with drilling the hinges. Part No. HS-1223. Should this have come with the kit? Cannot find it. Any help appreciated. Jim.
B BigJohn Well Known Member May 22, 2011 #3 If I remember correctly, the drill guide came in one of the very early kits - empennage I think. Check the inventory sheets. John
MacPara Well Known Member May 22, 2011 #4 It was in one of the bags of the empennage kit. Actually they provided two as the holes will wear out a little over the use ...
DonFromTX Well Known Member May 22, 2011 #5 When you find it, be careful to realize that each side is different. Very easy to get it flipped over when moving it down, then you get to buy a new hinge.
C clucier Well Known Member May 22, 2011 #6 Yeah I got a little drill happy and drilled all for pieces one way, OOPS, hello Aircraft Spruce, I need a hinge
DonFromTX Well Known Member May 22, 2011 #7 I was an equal opportunity driller, just could not keep it turned the same way!
S spriteah Active Member May 23, 2011 #8 Found it. Thanks. It worked out good. Today I found it hidden away. Taken all your advice and started drilling. Thanks all for the help. Jim. 12130.
