Drum
Active Member
Hi - I was just reviewing plans to check for location/size of drain holes and safety wire with the exception of firewall forward. Here's what I found. Please add to list if I missed some things.
Drain Holes:
Reference Description
DWG 7 0.25" hole bottom of R411 low point when in
ground attitude.
DWG 74 #40 drain hole in front of each bulkhead in
tailcone.
Safety Wire:
DWG 43 Tank attach angle bolt.
DWG 79 Flap Motor
DWG 84 Baggage Door Lock Assy.
Section 10, 10-2 Main Wheels and Tires
Section 10, 10-3 Gear Leg Fairings
Section 10, 10-6 Main Gear Leg Fairings
Section 10, 10-10 Finishing Wheel Fairings
DWG 4, View A-A Trim tab hinge pin
Section 7, 7-12 Flap hinge pin
