rvmv
Active Member
Was wondering if military aircraft use adsb so they will show up on my cockpit display. Thanks
The military will be using ADSB. Like transponders and the like, the system can and will be turned off (or to a discreet mode) during combat.
But...They have been slow to install the technology. Only about 1/5th of military aircraft will be equipped for ADSB by January 1, 2020.
Perhaps...
The answer to your question is a definite "maybe".
I agree with Kyle in that I wouldn't count on the majority of them showing up as you're out there flying around.
Patrick
There is a PRIVATE Facebook Virtual Radar and ADS-B group that monitors Virtual Radar and military. They post info of military and Air Force One tracks all the time. Late November, there was a post about two RQ-4B UAVs flying over Estonia and Greece.
Military ADSB
In the fighter development program I recently retired from Mode S ES (ADSB) was a late after thought but it was implemented. But there is no ADSB in? So the fighter aircraft gets no big traffic picture in the normal civilian traffic environment that we now consider standard and can only detect a RV or any civilian ADSB equipped aircraft if it's either visual, called out by ATC, or picked up on its radar. While the fighter does have a basic IFF interrogator when the ILS is selected it turns off the IFF interrogator and that function is replaced with a Marker Beacon receiver function. Yes Marker Beacon (I know what your thinking). There is no GPS approach function or WAAS that we would consider standard. Plane uses Software function com/NAV radios and requires years and millions of dollars to change.
The F/A-18A-G won't have ADS-B out for a while...so keep your eyes peeled when you're flying around low level routes / R-2508...
All tactical aircraft are on their own schedule of when, and potentially if, they will have ADSB Out. You would not believe the cost of getting FAA approval of a military solution to trying to be seen by others in aircraft that don?t want to be seen.
You didn't to mention the more recent incident coming back from Forks when you saw a Growler (didn't know it at the time) on your iPad (and I soon saw it on mine) coming in from the ocean at super high speed. He slowed to about 280 kts and boogied on by toward the Air Station. Passed me about 1,500' below and maybe 2 miles distant. He didn't have ADS-B out, but showed up on ADS-B in.
