flyboy1963
Okay, new RV-9a owner here....but last week doing my first flight in a month, my walkaround included sluicing a lot of wet frost off the entire plane.
With the opportunity to run my hands over the entire thing, I had the urge to squeeze the trailing edge of my lowered flaps.
Yup....crunch, crunch, went the ice inside! I see no big structural or aerodynamic problem, except that a LOT of water could swell as ice and start to pop rivets!!! ....ditto ailerons, not to mention the imbalance and flutter possibilities.
I'm going to add drain holes along the bottom edge. I find me and everyone else catches their toe on the flap if boarding with it in the up position, so I tend to leave them down until after startup.
Yes, best to raise them prior to start, but could need the battery juice when temps are below freezing, right?
so what's the consensus here?....to raise, or lower???
..by the way, there was frost on the BOTTOM of the wing also!...don't be fooled. ...the poor guy at the FBO had to de-frost
an entire Dash -8....by had!
